Which of the three oils??? For engine :
For cold engine oil level inspection have the motorcycle leaning on its jiffy stand on level ground, pull out the dipstick which is right behind the cam cover and the oil should register between the add and full marks DO NOT add oil if it is at the halfway point from add to full marks on the dipstick. Only add oil when cold if it VERY low. THE warm the engine to operating temperature and then let it idle on the jiffy stand for two minutes on level ground and turn the engine off and check the oil. Add oil only to just below the FULL mark. DO NOT fell over the FULL mark or you may encounter all sorts of problems.
SOURCE: capacity of primary oil on a 01 dyna wideglide
Three quarts. Check the oil level with the bike on the side stand. The dipstick has two marks on it. The top mark is "Full Hot" and the lower mark is "Full Cold". Maintain the oil level between the two lines. Do not overfill.
