SOURCE: Replacing dryer belt on Maytag
i would take off the cover, it might be reg or star type screws and look at this page
http://www.partselect.com/ModelFrames.aspx?ModelID=64957&ModelNum=DG410&mfgModelNum=&ManufactureID=1&Selected=36056&Position=6&mfg=Maytag&Type=&Mark=6
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
SOURCE: Thank you, it was definitely
Bravos dryer service manual page 55 shows the belt config
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Our Maytag Bravos Dryer, MEDB850WQ0,
Hello &
Welcome to FixYa If the belt
comes off then it is recommended to replace it. However, you can check this
video on how to put a new belt or same belt: Please get
back to me if you have any other questions. Kevin
SOURCE: maytag bravos gas dryer exhaust belt came off
Probably because the exhaust ducting is clogged. A common problem on these.
Pop the top just like the old models and remove the front then the shroud and then clean her up.
