Did you wear static protection while you were working inside? That's not for YOU, it's for the electronics. They're wicked sensitive to static.
BUT... it might also be the case that you just didn't plug everything back in perfectly. Go back inside, wearing static protection, and doublecheck every connector inside. EVERY connector, even if it's on the other side of the board.
Turn off power. take off trim over door ( 2 screws). Remove 1 screw from top of keypad. Lift keypad up and out away from microwave. Use a Q-tip with 1 drop of alcohol to separate and clean between ribbon connectors. It is 1 ribbon that splits to 2 connectors. No need to unplug, Just gently clean between the 2 ribbons. They may seem glued together. When they are separated and clean put electrical tape between them. Reinstall keypad (1 screw). Reinstall top trim (2 screws). If it hasn't damaged the circuit board already it should work like new.
"Er Clean S" is a common error with Frigidaire which means
shorted keypad. The issue is with the touchpad/keypad that should be replaced.
However, before replacing the keypad you can unplug it and take it apart
completely and use a hair dryer to blow some warm air on the keypad assembly to
blow the moisture off. Hope this helps...please post back for further
assistance.
FREE FIX!! Before you do anything else try this....
Blinking display with "ER S" on this model is a "keypad error" NOT a control board error. It occurrs when a button on the keypad is "stuck" for more than a minute most likely from being corroded - which can happen when the steam accumulates on the underside of the counter and drops down onto keypad (an apparent design flaw which frigidaire will do nothing about) - all the techs I've talked to recommend replaceing the entire plastic keypad assembly (oem part cost $125 at my local store). But they sell just the switch that is glued into the assembly for 16$ at www.repairclinic.com and it is a thin plastic film with electronic circuits running through it. Before you buy it though, turn power off at breaker, then try gently prying the keypad switch cover (the strip with the buttons on it) off of the top of the door panel (It is stuck down with a double sided clear tacky strip - I did it with a thin butter knife) and cleaning off any corrosion on underside of strip and on switch. Gently replace the keypad cover strip and press down around the edges gently. Then turning power back on to machine and see if that fixes it - worked for me - FREE!!! Worth trying before you call out a tech
You need the PC Link software for your model.
All of these manuals can be downloaded at: http://the-checkout-tech.com/
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
