Says reading then no disc
SOURCE: JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
SOURCE: Hello,
If the JVC m606 requires a stipped wire to connect them then they should be fine just make sure you connect the right speaker to the proper output if your speakers have a specified connector on the end then you would have to cut that off and strip the wire. if your m606 requires a specified connector for the speakers then you would have to change the connectors out for the proper ones.
SOURCE: JVC TH-M505 "No Disc" Readout
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3.
check if there may be a pinhole somewhere along the bottom of the
loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6.
if the unit has been in use for some time, it may simply need cleaning
and re-application of lubricant in the mechanical assembly.
The
slider mechanism, depending on the age of the unit and , consists of
the small chrome rail, a drive motor, a small gear assembly, and (in
some units) a small belt that drives the slider unit via the motor.
This small belt causes all sorts of problems. If the belt is broken or
slipping, it can cause skipping, dropouts, or simply no start up at
all. Also, if the belt breaks in the middle of the disc, the drive
mechanism gets hair or dirt wrapped up into the gears, or the pick-up
assembly doesn’t return to the start position (called home), the unit
will (99% of the time) refuse to release the disc, causing it to become
stuck inside the unit. There’s a little micro or leaf type switch
located at home position that sometimes gets dirty or breaks and,
causing this problem also.
Hope this may help;
Regards,
VOTIT
SOURCE: how to get sound to tv from JVC TH-M606 without
** to "AUX input "
or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to
respective mode on JVC TH-M606 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the JVC TH-M606 Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
