Try a reset To restore the TV to its factory default settings: 1. Press the MENU button on the remote. The on-screen menu is displayed. 2. Use the Arrow buttons on the remote to highlight System and press OK. The SYSTEM menu is displayed. 3. Highlight Reset & Admin and press OK. The RESET & ADMIN menu is displayed. 4. Highlight Reset TV to Factory Defaults and press OK. 5. If you have changed the default parental control PIN, enter it now. The TV displays, "Select Reset to restore all TV settings to factory defaults." 6. Highlight Reset and press OK. 7. Wait for the TV to turn off. The TV will turn back on shortly.
If you have not set a PIN, enter the default, 0000
Restore the factory-set defaults
CAUTION:Restoring the factory-set defaults returns all of the product and network settings to the
factory defaults. The procedure then automatically restarts the product.
1.
On the product control panel, press (X451 Series) or touch (X551 Series) the Setup
button.
2.Scroll to and press or touch the Tools menu button.
3.Scroll to and press or touch the Restore Factory Defaults button, and then touch the OK button.
The product automatically restarts
To restore your Lexmark X6500 Series printer to its factory default settings, follow the steps below:
Press the Settings button on the printer operator panel.
Use the arrow keys to move through the selections until Defaults is displayed. Press the check mark button to accept this option.
Use the arrow keys to move through the selections until Set Defaults is displayed. Press the check mark button to accept this option.
Use the arrow keys to move through the selections until Use Factory is displayed. Press the check mark button to accept this option.
Use the arrow keys to move to the required country, language, date & time, time format, fax number and fax name and press the check mark to confirm each selection.
When the process is complete, the display will read Initial Setup Complete.
From the printer control panel, press Setup button > Defaults, press OK > Set Defaults, press OK > Use Factory, press OK. You will then be asked to select/enter your preferred printer settings just like the first you set it.
Source: How to Reset the X5600 and X6600 Series Printers to Factory Defaults
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default settings (except language) via the control panel or software NOTE: This service menu item does not reset factory-settable settings, including formatter number, page counts, factory paper settings, language, and so on. NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the information on these pages to reset customer-specific settings. CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset. Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus. 2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select). 3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK. The product automatically restarts.
Visit this link to download manual for EX-Z80.
Try to reduce the red eye function or try resetting the camera to the Default Factory Settings by performing the following steps:
1) Power on the camera in REC mode.
2) Press the MENU button.
3) Select the SETUP tab.
4) Scroll down to RESET, use RIGHT arrow and select RESET again.
5) Press the SET button.
Good Luck....don't forget to rate the solution.
Dear Venmattey, please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears: a. Give this new connection a name. Ex: EOC-3610. b. Select correct COM port. Ex:COM1. c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window. d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
