SOURCE: Panasonic SA-HE100 5.1 system error code F70
I was able to fix this problem by replacing a fuse. Remove the cover (7 screws). Directly behind the fan are 2 boards with 5 fuses on them. The boards are 1 over the other. The fuse I replaced was labeled F5 and on the top board with the fuse facing down on the underside of the board.
SOURCE: F70 ERROR ON PANASONIC AV RECEIVER SA-HE200
This is essentially a protection mode indication. Either the output amp pac is defective or the regulator circuit is bad. Either option could be over $75 in parts plus labor at a local shop.
Let me know if you would like to attempt the repair and I'll try to get you more specific parts information.
Dan
SOURCE: Panasonic SA-he75, displays an F70 error.
The F70 error is a code for "protect". See the link below for a general explanation of protect mode. Specifically for your unit, the output amplifier IC has failed. This can be replaced, but the parts cost will be in the $100 range. Please update this if you have further questions.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
