if its the 2 wires that go into the switch block then you need to push a pin into the holes under the holes the wires are in, that will release the wires. you should tin the new wires then simply push them into the holes you took the old wires out of,they will automatically lock in place
the upper section of the grass collection box is a fill indicator. this indicator shows green and turns red when full. it also triggers a power off switch. it sounds like some debris has caught between the switch and indicator.
with a fine dry small paint brush or cotton bud clean around the switch .
The feeder pin used by hitachi has a shoulder on one side and a rubber washer /retainer on the other. There is only one groove and the retainer fills the groove and if the correct pin and spring, no extra room to fit an exstra retainer unless the shoulder is worn so bad that the pin is falling thru the plunger. I have seen a lot of creative ways that owners use to hold the pin in place due to lost rubber retainer or lost pin. I also see many guns that have installed a retainer pin from porter cable which has two grooves (one on each side of the pin and no shoulder ). Porter cable pin works fine and fits perfect. Good luck
Can we get a Make and model number please? I am searching for any brand of hover mower that is 1250W at the moment and there are at least 3 different brands:
sounds like the engine isnt getting the power to turn it sorry but flymo mowewrs are a pain to repair as they some times cost more to do than buy a new one
