SOURCE: gprs setting
SMS Bsnlgprs to 5420............you'll receive...........................nothing hahahaha
SOURCE: In my set i am
Hi,I suspect it's related to your sim card (network), not your samsung cell phone. In most cases, regarding text messages, the problem is from the Service Operator. Have you tried the sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise versa by inserting another sim card on your mobile.
If you can't receive text messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
If the same sim card doesn't receive text messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
Have a nice day.
SOURCE: I have a Nokia 1209
Go to your message
setting then to text message setting and make sure your message center no is
entered correctly...If not there then ask it from your customer care and then
enter there correctly..after that you will be able to send sms..
SOURCE: Can't activate Bsnl gprs on
There is a special service called BB service for blackberry normal gprs connection will no work on phone ,regrds
SOURCE: i cannot send sms, but can receive sms and
check ur msg service center no. ang change it into default........
You can ask for the settings by sending space of your handset to 58355 by SMS e.g. space to 58355. After you send the SMS you will in response get several settings on your handset viz. 'bsnl live', 'bsnl stream', 'bsnl mobility' etc. You may also call BSNL Customer Care Center to know the settings.
Once you get all the settings, you will have to save them. Out of theseseveral settings the one pertaining to BSNL Live (will appear as 'bsnl live') should be saved as default.
Hope you will be streaming videos faster using 3G on your mobile.
Great time with 3G and Please vote if helpful
