Akai LCT3201TD 32 in. LCD Television Logo
A
Anonymous Posted on Apr 13, 2014
Limited channel i can only get a few channels
Nigel Gibbon
Level 1:
Habit-Forming:
New Friend:
  • Contributor 14 Answers
  • Posted on Jan 21, 2017
Nigel Gibbon
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
14
Questions
0
Helped
11079
Points
21
There are unfortunately areas where tv channels are limited. For example, Dorset has something like 27 available channels. If you're in the U.K., check Freeview coverage for your post code. (Using a search engine).
Hello, my wifi connection is constantly dropping, showing limited conectivity.
One of the most common causes of this is wifi channel interference. Most routers come preset to "auto" which allows them to choose whatever channel they wish to transmit on. And most use the same defaults. If you live in a relatively congested area where there are many wireless networks around, having all of them on auto can start a cascading shifting of channels to try to avoid interference. One or two shifts most devices can handle, but when it cascades, most devices just disconnect. Best thing to do is to go into the router and manually select a channel to use. Try it for a while. If you have no more problems, ok. If not, change to a different one and try again.
Do all members in a YouTube group recieve a YouTube Play Button Plaque???
https://www.youtube.com/yt/creators/rewards-details.html
Who qualifies? Any YouTube channel that has passed a certain subscription threshold qualifies for the rewards.
What are the thresholds? We have two levels of rewards: channels with over 1 million subscribers; and channels with over 100,000 subscribers.
When does a channel qualify? A channel only needs to pass the threshold once to qualify.
What are the rewards? We are recognizing those qualifying channels with 100,000 subscribers with a limited edition, commemorative Silver Play Button.
For qualifying channels with over 1 million subscribers, we are recognizing them with a limited edition, commemorative Gold Play Button.
How long will it take for my rewards to arrive? Once you have uploaded your shipping address in the rewards redemption website, the rewards can take eight to twelve weeks for processing and shipping, depending on your location.
Are there other qualification criteria? We want to recognize those channels who have honestly earned the achievement. To prevent any channel from gaming the system with falsely inflated subscribers count, we use a variety of signals to determine which channels qualify for rewards, including but not limited to subscribers, views and watch time.
Will additional rewards be given in the future? We intend to administer the program on a quarterly basis and rewards will be given out to newly qualified channels several times a year.
2answers
Drop channels
do an auto channel search from the tv menu
Wireless detection is faulty. It appears to detect some networks (usually low-signal ones), but it doesn't detect our own wireless network router which is a few feet away. I have another laptop and it...
Hi Thanks for your question.
You can try and change the channel that router is broadcasting on. This can be an issue sometimes. Change it to something popular like channel 4 or 8. I hope this was helpful. Good Luck
4helpful
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Motorola dvr dct6412 locked channels
Check with your provider to ensure that you are in expanded services, or limited. Because being on limited services the box will lock you out of those channels. If you are in billing for those services and you checked the batteries on your remote and they are good and you get a solid red blink when you change channels not a double blink (indicating that your batteries are dying), Then try power cycling your DVR by, removing the power supply and waiting 3sec then plug it back in. Your box should shut off, turn itself back on, then go into the load screen, then, once the load screen display shows on your tv and on box display, wait for your box to completely load (don't touch nothing until the correct time shows up, meaning that it has completed the load process) Once the process is complete turn box back on and you should have you guide back up and (No Data) on your program schedule(Don't Worry!!) it will populate, with 15-20 mins.
Now try to ch. up and down and see if that fixed the problem. also make sure nothing is blocking the sensor. If all else fails and you changed the battery, called your cable provider and request a box swap, (be sure to watch all your recorded shows because they go bye, bye with the cable guy!)
Limited access
If you have limited access, that means you need to change the wireless channel of your router. Using your wired computer, open the router's setup page by going to internet explorer and type http://192.168.1.1 and press enter. It will prompt you for username and password. By default the username is blank and the password is admin. Look for wireless tab and look for wireless channel. Change it to channel 11. Make sure to take note of the Wireless Security key as well under wireless security tab. Save the settings after changing the wireless channel. On your laptop, make sure to disable any firewall then try to reconnect to the wireless network.
Limited channels
Go to the following link:
http://www.xmradio.com/refresh and refresh the radio. If no net access, call 800-967-2346. Have the radio code handy. It may work.
2answers
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Limited channel selection
Select cable in menu instead of Ant. and reprogram channels.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
