Question about Uniden BC895XLT Base Scanner
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM;
118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed
into its 50 memory channels. It does not have a VFO or dial
mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel,
press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1:
Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning.
To turn a bank on/off, press its number while in Scan Mode.
Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second
in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using
keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR
& re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY”
in display. Same deselects.
• To lock out channel from scan, select it & press
LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through
channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually,
then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Posted on Jan 19, 2010
