The problem might be the speakers try hooking them up to a small house stereo to test the speakers if the mids work then its gonna be the connections from your unit
Could have damaged the speakers or the radio or both. You could pull a door panel and connect a small used speaker to see if the radio is producing a feed to the door.
There is a wiring, connection issue from the laptop to the speakers.
There is a driver issue. Try clicking uninstall on the speakers. Under device manager, right click the speakers and click uninstall, and then click scan for changes. This will attempt to install the newer drivers.
You will need to take the speaker apart and with an ohm meter or continuity tester, measure the resistance of the speaker, at the two terminals at the rear of the speaker magnet, to see if that circuit is "open" ("open" is a reading of no resistance, or no continuity). If it is open, you have no choice but to replace the speaker. If instead the speaker measures a low resistance, or the meter "beeps" to indicate continuity, then do the following: measure the resistance/continuity of the wires which lead from the speaker magnet, to the output terminals on the outside of the speaker box. Also, some speaker manufacturers install small fuses inside their speakers. Even if the fuse does not look "blown", test it for resistance/continuity. Good Luck!
You will need to take the speaker apart and with an ohm meter or continuity tester, measure the resistance of the speaker right at the speaker to see if the speaker is open. if it is you have no choice then to replace the speaker. If the speaker measures a low resistance, measure the wires froom the speaker to the output wires or terminals. Some speaker manufacturers install small fuses inside their speakers. Good Luck
