SOURCE: TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
SOURCE: tv shut down wont go back on
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge,or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees.
SOURCE: TV itself works fine. The problem comes when we
Hi gerry, my name is John. Welcome to FixYa. Check the format of the movie in question. Thanks for choosing FixYa....John
SOURCE: Have Sanyo DP42849 and need
The specs for this tv does not show it is netflix ready. You may try a Blue Ray player that is Netflix ready and use it for downloads.
SOURCE: My netflix takes a long
Netflix web site movies.netflix.com has recently had problems with streaming service and activations.
Reference:
http://www.huffingtonpost.com/2011/06/20/netflix-down-site-streaming-offline_n_880162.html
