SOURCE: NEC DTerm 80
Try dialing the numbers 725 and then hang up...to turn it off..same thing. Ours works this way at work.
SOURCE: NEC Dterm 80 / change contrast on display panel
Use the up/down arrows on the bottom right. Though you may think they are volume, it actually is for contrast when the phone is on-hook.
SOURCE: I WANT TO TRANFER CALLS TO MY CELL NEC DTERM 80
speaker 47,9+1+area code and number....beepbeepbeep hang up.
SOURCE: NEC Dterm 80 LCD display is defective.
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
