Homepage set as firefox in options but yaimo is showing on start up page when opening firefox
SOURCE: Firefox Error
Try rebooting your computer it might do the trick, if this fails, make sure your internet connection is working properly.
If the above doesn't work make sure that –
File > Work Offline Is not checked!
Good luck.
SOURCE: uninstalled internet connection icon.
Ok...from the above comments..if it problem still persists...would suggest uninstall IE 7 and install the default IE 6 along with the WIN XP..hope the machine also has good specifications....should work fine...From above comments.....antivirus, applications tend to slow down the machine...try to upgrade if possible..RAM etc..paging////
If found Ok..then agin try and upgrade with IE7
SOURCE: When I open Firefox my homepage (MSN) occasionally
mso 9]>
Normal
0
false
false
false
MicrosoftInternetExplorer4
mso 9]>
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
mso 10]>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You might want to check your computer for spy ware programs
and also clean your temporary files
For spyware try the next link, this is a freeware program
that cleans most of the spyware programs:
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
To clean your temporary files try the next link, the
CCleaner program is a freeware system that cleans all temporary files on your
profile; also try the Registry cleaner that is included.
http://www.filehippo.com/download_ccleaner/
Good luck.
SOURCE: Toolbar showing Bookmarks Tools etc did not appear
You will be able to see the Menu bar after pressing the "Alt" Key on your keyboard.
SOURCE: Why when enabling the firefox popup blocker add
u can try this open firefox go into options then select content now select exceptions and add your site. also check to make sure all your addons are update to date; i would also recommend u install the add-on compatibility reporter.
