Yamata PSS-2001 Power Stand-Up Steamer for Clothing, Curtains, Linens, Coats, Reduce the need for ironing;Remove wrinkles and creases from clothes still on hanger, Never scorch even the most delicate fabrics, Clean and professional results every time;Lighte Logo
A
Anonymous Posted on Mar 31, 2014
I need a water bottle for deluxe steamer pss-2001
The water bottle is cracked and I would like to find a replacememt
1helpful
What is wrong with my Eureka enviro steamer?
It is limescale. Basically your steamer takes water and boils it dry and turns it to steam. Any minerals like calcium in your water is left behind as rocks or flakes.
It should be descaled once every couple of years. You can do it fast with a product like CLR, or overnight with white vinegar. Fill it up and leave it, next day, turn it on and get it hot, but not boiling. Turn it off and leave it to cool. Empty and rinse 3 or 4 times.
Where can I get a replacement plastic part?
Try the place that you bought it. They may have the supplier / manufacturer information of where you can get parts from.
Why doesn't carpet cleaner dispense water and soap?
Get a needle and clean all the nozzles, since they work with hot water they tend to get clogged with a white built up.
Why is there no steam?
Plugged in? Add water? Check the fuse on the power cable.
Home touch garment steamer model ps-280 wont turn on
If it were left on its possible that the element that heats the water has burned out think blown light bulb have your Mr Test it with a ohm meter to see if the circuit is open
Where can I get parts for the Yamata PSS-2001? I only need casters.
Best way is to contact manufacture for part information and part dealer near your location
Home Touch PS 250B
Best way is to contact manufacture and ask for part dealer near your location
2answers
Home touch ps-250B steamer
Need Water Tank top cap which is brocken
Top Yamata Garment Steamers & Presses Experts
ADMIN Andrew
ADMIN Andrew
john h
Stan Ford
Are you a Yamata Garment Steamer and Press Expert? Answer questions, earn points and help others
