Orbit single outlet digital timer. top screw to tap connection leaking badly.
SOURCE: Leaking Kitchen Tap
yes your right it's the seal inside and it can be replaced you should shut the water off after all why make a mess when you don't have to. however I'm not familiar with this typ of faucet. you more than likely be able to get help from your local area hardware store when you purchase your gasket for replacement.
SOURCE: leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
SOURCE: MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
SOURCE: Hi! My hot water taps from the wash hand basin and
In a word no. Combi boilers work on balanced pressure.ie the mains cold supply to the boiler should be around 1 bar minimum which would give a hot water pressure of the same 1 bar. Assuming the cold water pressure is fine, it sounds like you have a restricted flow on the hot side. If you live in an area with water problems the hot water systems pipework calcify over time effectively reducing water flow. Unless any flexi hoses are kinked, check if there are any filters in the appliances that may be blocked.Also check all valves are fully open and if possible check if there are any restrictions at the valves. Failing all that and the taps are in good order it is possible to fit a pump before the boiler but this may only be a temporary fix overall.
