Question about PC Chips MB PCCHIPS P21G (V3.1) P4M800 775 Motherboard
HOW TO CHANGE BIOS SETTING FOR WIN7
WILL NOT INSTALL WIN7
I need driver for Hitachi GD2000 2X ATAPI/E IDE DVD-ROM Drive to complete a win7 install
You're not going to get an install then. If that is NOT an OEM Install disc, you might have to try another drive to do the install with. Most ATAPI/IDE Drives are run by the BIOS.
Feb 01, 2014 | Compaq HITACHI GD2000 2X ATAPI/E IDE...
Windows 8 Gateway desktop trying to load Win7. I
Hi
You can try with Free Boot Managers and Multi-Boot Loaders you can find lot of free stuff available in online. So download and follow the instructions.
OSL2000 is an advanced multi boot manager you can install multiple OS in a Single PC.
Hope this will be helpful
Have a good day.
Regards
NANDU
Aug 28, 2013 | Gateway SX2865-UR11P Desktop Black
Intel DQ965GF Motherboard won't load WIN OS (WINXPPro volume disk or Win7) tho an old Dell disk did load. Is there a fix? Thz
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF
Windows 7 is not a supported system, but you can use the drivers from the vista system, but only the 32 bit.
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
After the post, BIOS will attempt to boot from the first device listed in the boot order.You need to change that, so the first boot device in the list is the dvd drive. If that device is not bootable, BIOS will attempt to boot from the second device listed, and so on.
Note: The boot order is a BIOS setting so it's OS independent. In other words, it doesn't matter if you have Windows 7, Windows Vista, Windows XP, Linux, or any other PC operating system on your hard drive or other bootable device, these boot sequence change instructions will still apply.
Here is how you do this:
http://www.hiren.info/pages/bios-boot-cdrom
But ofcourse there could be a problem with the dvd drive or harddrive.
To install windows 7, you will need at least 1 gb ram or more, and a dual core cpu.
Best of luck
Feb 12, 2013 | Computers & Internet
Unable to install xp on presario cq56
Go to BIOS and change SATA operation from AHCI to ATA
Apr 26, 2012 | Compaq Presario CQ56-115DX Laptop
How do you install windows 7 on HP pavilian 754n? plz tell me quick because we just bought windows 7 and it doesnt work on the computer. thx you!
First you will need the Window 7 operating system cd.
place the cd in the cd room and let the auto run take place. this is not a quick process
it will take several minutes. If the operating system is not loading you may have a different problem
Jul 19, 2011 | HP Pavilion 754n PC Desktop
I purchase compaq laptop model no CQ61-312TU they have a factory installed windows 7, i have fully format hard disk and installed windows XP but in Boot they show me Error, I check the BIOS setting , The...
you are getting blue screen because of compatibility issue. go into bios (press f2 on start up) and change from sata mode to ahci compatibility mode 'probably in the advanced section). you should then be able to boot from xp cd. remember to get your xp drivers from the hp website.
Apr 11, 2011 | Computers & Internet
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
Jan 22, 2011 | Computers & Internet
I am attempting to install Windows 7 on an AlienWare M7700 D900T laptop, but Windows Setup will not recognize the hard drives. When first I boot up the laptop the hard drives are clearly detected, IDE...
It is a 2005 machine and was designed for Vista so an upgrade from Vista to Win7 may work as the drivers will need updating as it loads one OS from the other OS.
A bios update would possibly help also.
Jan 16, 2011 | Alienware PC Systems M7700 Notebook
BIOS cant display(in BIOS option no data write there), and i cant chang my BIOS setting. now i cant formeting my leptop, & any operating system i cant install. at pesent o/system is win7...
to get into bios hit f-2 at start up go to bios and restore it to default setting
if you have a sata hard disk then disable it in bios setting
or RAID Auto/Ahci to RAID Auto/ATA
then reboot from installation disk hope this helps and remember to vote
Nov 29, 2010 | Computers & Internet
Instaled win7, but forgot to update the bios. So I'm trying to re install XP from the disc that came with the computer, update the bios and then re install win7. y problemis that i don't know how to boot...
Power on netbook, before booting up, press F9 or F10 or Esc Key(it varies on different netbooks), go to the boot options, change the boot order priority and make your DVD drive the first boot option and then your hard drive. now Put the DVD, save the settings. Now it will load the DVD and the set up screen will come.
Apr 18, 2010 | ASUS Eee PC 1000HE Netbook
Computers & Internet Logo
24 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
