Where is the tcm module located? I changed the egr valve and still get the wrench light on dash when car is wearmed up. then it wont shift out of first gear im told the tcm module needs replaced but not sure. the engine light is not on.when i shut off the car and start it again the wrench light goes off and it drives and shifts perfect....idk
Awd malfunction light on,tcm not communicating and not enough voltage to vehicle
Fix your car right away, by clicking the link FORD FIVE HUNDRED 500 SERVICE REPAIR MANUAL 2005 2007 DOWNLOAD
SOURCE: 98 Ford Taurus shuts off when shifted into gear.
its in the timing ...whenever you start it it sits and idles fine but when you go to put it in gear it dies...the timing needs to be repaired. its a guaranteed solution.
SOURCE: AOD trans wont shift when cold
Ok I have no Idea who told you not to change the fluid? However there is a reason you have to drop the pan to drain it, or change filter and the reason for this is. So you cant just change fuild and leave dirty filter in, or change filter and leave dirty oil in. Your wouldnt just change one or another on your motor would you? lol Anywho your problem is either burnt fuild. Yes the fuild can be come burnt and lose it vascoity, and weight. (basicly your runing gravey through it.) lol Or the fuild is termendously dirty strained or not. FYI there are clutches in your transmission.... Have you ever heard of clutch dust? Well in an automatic because of the fuild its not clutch mud..... explaining why when its cold and the oil is super thick it has problems, but when it thins up when its warm its fine.
CHANGE YOUR FLUID & FLITER
SOURCE: Gear Shift not shifting properly
Depending on whether it is a column shift or floor, you have to get the linkage loose enough to get the car in neutral, move the selector back to the proper setting, and tighten everything up.
If the car is not setting on a hill or incline, you should be able to move the shift levers by hand when you've loosened the linkage and move it until it is in neutral. Put on jack stands and chock the wheels that are on the ground.
SOURCE: I have a 2005 Ford five hundred and the
You need to have the transmission serviced. The wrench indicates that the fluid in your transmission is out of spec or you have an out of spec pressure condition.
My car shift gears fine not enough voltage to vehicle
