Cannot work the alarm
SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
SOURCE: My Emerson IC172 Clock Radio won't recognize iPod
For this type of problem you will need to talk to Emerson Customer Support. They will know if the functions you want will be available to you with the operation of the Clock/Radio and your iPod. The telephone number for the Emerson customer support is 1-800-909-1240. You can call them during the hours of 8am-4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information help you solve your problem. Thank you for using FixYa and have a nice day!
SOURCE: How do you set the clock and alarm on the Starlite
Setting the clock for the Ipod docking station
NP105CR
Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
866-387-2027 for manual
