You would lay out a table with the corresponding numbers that are on the wheel. Same concept as roulette. Player puts a chip(s) to the number of their liking.
Sound like you need new shafts or paddles and I know the paddles can cost $30 each. so think about a new model or buy one at a thrift store and try those paddle or use the machine. I got a great one for $10 . :)
Check the paddle wheel under the lower (conical) burr. You should be able to see vertical paddles that move the ground coffee. If any are broken or missing (very common if you've used rice intead of Grindz to clean the burrs) you need a new paddle wheel, which you can buy from Baratza.
I dont have a solution for this problem, just to say that XBOX support offer no service to repair the wheel. My own wheel has suffered the same problem, and I have been advised to fix it myself. ... Thanks Microsoft...
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
remove the bottom pan by pulling it out, then you will see three screws. remove the screws. Push the fram up which will unlatch it. The asbly will now come out. pull the water hose and the electrical connector, and you'll see the screws that hold the paddle.
How to fit Washing Machine Drum Paddle Lifter For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter. A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple. The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out. Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines. There are few types of drum lifter; drum Paddle lifters On hotpoint, creda, Ariston ,indersit and someother makes see video To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine. Huge selections of lifters are available on thewebsite DrumPaddle lifters
