-My air compressor runs and sounds great, but it only-builds air to 25 psi but no more. I checked the cylinder, piston, and rings and everything looks perfect. The only thing I noticed was that when the compressor is running air blows out a small hole located at the top of the oil fill plug, which I believe is done by design. The compressor will maintain 25 psi on the gauge overnight with no bleed down and it does not shut down since it doesn't ever build up enough pressure. Therefore, it runs continuously until I shut it down manually.
Please Help!
SOURCE: Mastercraft 2.0 hp air compressor will not build up over 25 psi
sounds like a bad or broken valves in the head. crankcase needs a vent which is sometimes a small hole drilled into the oil fill plug and will normally blow some air out the vent while it runs
Thanks for your reply, but the pressure switch is fine, and the compressor does NOT ever shut off because there is never enough presure to engage the presure switch.
