I CAN NOT GET PERMISSION TO THE UNIT IT SAYS I AM ONLY A GUEST AND THERE IS NO PRIMAY ACCOUT
SO I AM NOT SURE IF I WAS SLEEP COMPUTING OR WHAT BUT WHEN I went to use my tablet the next day i was just a guess and there is not another user to switch to i guess i must have changed the primary user to have no permissions at all what can i do to get control of the computer again thank you
Its ******* to close some else account on the facebook without his/her permission/ concern. If that person is asking to help him/her to do so that then its fine.
Do you have the expressed permission to do this? The intentional breach of a computing system to include web servers, databases, computers etc is strictly forbidden and it is illegal via various acts including the Computer Misuse Act which is embedded into U.S. Code therefore, it is prosecutable in Federal Courts. Is it worth it? If you do, however, have permission to get into this account. You will want to search for HTTP Proxies/Interceptors (hint: FireFox Add On). Monitor the request when you submit "forgot my password" what is the sendto: address?
You may be logged on your computer using a guest
account. A guest account can access the computer but has limited rights and
permissions (e.g. downloading applications, computer configuration changes,
install software or hardware, etc). Please ask your technician or access the
Administrator account to successfully install the printer driver. You may also
ask the owner of the Administrator account to grant you additional rights and
any permission to your guest account so you can make future changes.
Welcome to FixYa, the world's largest product support community.
"...Microsoft Windows 2000 and later support hibernation at the operating system level (OS-controlled ACPI S4 sleep state) without special drivers from the hardware manufacturer..." Source: Wikipedia URL: http://en.wikipedia.org/wiki/Hibernation_(computing)
guest, FP2226AFW may have internal "switch-mode-power-supply" problem. Swollen electrolytic filter capacitors or "thermally fractured" component leads to printed circuit board solder joints that will need to be "reflowed" to restore unit to normal operation. Prove that problem is monitor by swapping-in a known-good monitor to your pc first!!! If pc is ok, then 2226AFW unit will need "tear-down" and Inspection" of it's "switch-mode-power-supply/cold-cathode-fluorescent-lamp INVERTER power supply printed circuit board. Do some reading in my fixya profile and those of other CCFL back-lit lcd monitor tech's and you may just find a solution. All CCFL back-lit lcd monitors of the same basic design and functional operation. 12fixlouie
If you want to change the name from Administrator to something else, simply click Start - Control Panel - User Accounts and click on the accout you want to change. There you can change the name and photo that appears for your settings. If you want to add another account click on Guest Account. Hope this helps. You can also add a password.
Unfortunately, the unit is not going into "Sleep mode". The PROTECTION error actually means that the unit is overheating. The unit shuts itself off to avoid further damage. Try to make sure that no other device is below the unit. Also make sure the unit has adequate ventilation on the back of it. If not, call 1-800-7267864 and let them set up a repair order for the unit.
Make sure that you have an Xbox Live Gold subscription first,
Second You won't both be able to play at the same time enless it is a game that provides guest support(and in some games WITH) guest support you cannot play anything ranked online. To sign in a game with Guest support hit the guide button on the second controller select choose profile and scroll down, if u see "Guest" as a profile and you did not create it, then that game has guest support, and you can both play.
______________________________________________________
If u are just trying to let him play alone then you have to sign him in how you would normally
