Security code for nokia 3110c. I want to reset the time of the call and the number of sent messages. My IMEI number: 354834/02/580153/5 The phone is coded with one operator, and I like to download the code and be able to use more operators. Is it to be?
there are two methods to reset the security code... firstly give me the
IMEI number of you handset and i will give you the master code to reset
the security password..its free
or the other one will be chargeable.. you will update your phone
software all security password will reset and default password will set
"12345" for nokia 3110c... its chargeable
i am also having the nokia 3110c... i was also having the same problem so i used the first method... free one
note my email id give me the IMEI code: [email protected]
thankyou
Hi sir, i have nokia 3110c and i have forgot the security code which i had changed from default i.e 12345..and the new security code i had forgot...please help me out to unlock mine phone as if i have mine important contact numbers and data in dat phone pls help me out for this...
357593006548708.........for this phone try resetting the phone or formatting by entring *#7870# for resetting and *#7370# for formatting in any of the case you should have your original number which is 12345 as the new code after resetting of formating but for formtting you would lose every contacts so you are advice to keep a copy of every important dorcument.
for nokia 5300 also try resetting or formatting to restore the usual pin code "12345" and to do this first copy all contacts and information need first even is restting it(which you do not lose any information) ........... to reset enter *#7870# and to formate enter *#7370# please try the first method before proceeding to the second one.
for nokia 3110c please this is your master code 6003104322
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want? The default security code for Nokia is 12345
