Dehumidifiers Logo
A
Anonymous Posted on Mar 17, 2014
Waveline model WL2110BP
Motor starts ok but stops after 2 minutes, Water tank is empty
Midea Cube 20-Pint Smart WiFi Dehumidifier is stuck on 'Water Level 50%' even though tank has been emptied multiple times. How do I reset this?
If your Midea Cube 20-Pint Smart WiFi Dehumidifier is stuck on "Water Level 50%" even though the tank has been emptied multiple times, you can try the following steps to reset it:
  1. Unplug the dehumidifier from the power source and let it sit for 10-15 minutes.
  2. While the dehumidifier is unplugged, remove the water tank and check for any obstructions in the water tank outlet or on the float switch.
  3. Clean the water tank with warm water and mild detergent, then dry it thoroughly before replacing it in the dehumidifier.
  4. Plug the dehumidifier back in and turn it on. If the water level indicator still shows 50%, try pressing and holding the "Water Level" button for 3-5 seconds to reset the sensor.
  5. If the issue persists, try performing a factory reset on the dehumidifier. To do this, press and hold the "Timer" and "Mode" buttons simultaneously for 3-5 seconds until the display panel shows "F". Then, press the "Power" button to turn the dehumidifier off, unplug it from the power source, and wait for 5-10 minutes before plugging it back in and turning it on.
If none of these steps resolve the issue, it may be necessary to contact Midea customer support for further assistance or to have the unit serviced by a professional.
I have an Idylis dehumidifer with pump model 0526051 does it need a hose in the water tank to pick up the water in the tank?
Normally dehumidifiers collect the water that they have pulled from the air in the tank. Therfore no hose is required. You just have to empty the tank when full. Most models have a float switch which shuts off the machine when the tank is full. Hoses to get rid of water are normally only fitted on industrial machines.
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    I have misplaced my operating instructions for my Danby dehumidifier model DDR 3008 EE. When I plug it in, turn it on, it runs for maybe a minute then the red full water tank lights up and it quits. The...
    The model number you listed did not reveal anything. However, the link below is a link to a Danby model, that had a model number closest to yous. Most of the units have the same parts and function. Click n the literature tab and the Owners Manual will come up.
    http://www.danby.com/product/DDR30E/12
    Hope this helps you. Please let me know.
    My unit stopped working after less than 1 year . It will occ start up dor a few secs and then stop again??
    The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
    If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
    Good luck
    9helpful
    3answers
    My zenith zd309 light keeps blinking but the water
    If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
    1helpful
    2answers
    No water in tank
    have you turned them off, waited a long time, and restarted? if yes, but still problem, both have developed freon leaks. the coils may have "frozen over", verified by looking at them-do they appear frosty? caused by humidistats that are not functioning properly (starting to corrode)...try turning down the stats to allow motors to rest (and frost to melt)
    Danby water tank
    this part is the indicator to activate the interlock that stop your deshumidifier when water tank is full. It activate a switch on the top right of the placeholder of the tank. when the switch is relaesed it tells you either thank is not there or full and light a red signal. the center of the wheel should be back the pivot. if the pivot is broken, i don't suggest you to forced the switch activated unless you use the direct drain, or you might have water spilled over a full bucket! Martin!
    Top Dehumidifiers Experts
    ZJ Limited
    ZJ Limited
    ADMIN Andrew
    ADMIN Andrew
    Are you a Dehumidifier Expert? Answer questions, earn points and help others
