clean up the heads with a cotton bud and clean or isoprop alcohol; if theres non or unacceptable difference then check for a cheap head demagnetizer on ebay or ask if your local electronics repair shop can do it for you
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection: - iPod will not be charged - iPod can not play music through the Sony - iPod will play music through the Sony, but an iPhone won't
This happened to me - the radio also wasn't playing. I was able to resolve it by resetting the unit using the instructions in this manual: https://docs.sony.com/release/ICFCS10IP.pdf
I have the same tape deck. To do a copy on this machine you first press
the normal speed button below synchro dubbing, then hit the pause button
on the recording side to start the copy. It will automatically start
both decks.
And to stop the recording hit either of the stop buttons.
Step 1. Put on your PSP and use the arrow keys to go to "Saved Data Utility". Scroll down to "Memory Stick" and press the O button to get into the games stored in your memory stick.
This would enable you play your games on your memory stick, but if you are still not able to do that then get a UMD to play games or verify the version of your PSP.
You can only play the games in the memory stick after the PSP has been hacked.
if the square belt kinda serpentines in and around a couple pulleys (or did originally) then it did not get put back on correctly. try to think of another way it could be threaded through the pulleys.
