Motorola MagOne BPR40 UHF 8-channel Two-way radio AAH84RCS8AA1AN Logo
A
Anonymous Posted on Mar 16, 2014
How do i sync Two-way radio AAH84RCS8AA1AN - Motorola MagOne BPR40 UHF 8-channel Two-way radio AAH84RCS8AA1AN
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Jan 07, 2015
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
797172
Points
4248
These are dealer programmable using Motorola proprietary software and the appropriate cable. Most Motorola dealers could program one or more of the radios for you.
2012 ford radio only shows ford fusion
https://owner.ford.com/how-tos/sync-technology/sync/settings/how-to-perform-a-master-reset.html
first check all fuses to make sure that isn't an issue. Then try the steps in the following link to perform a hard reset. If that still doesn't resolve it the radio will probably need to be repaired or replaced.
BPR40 Receiving a static reception when someone is talking
Several things need to be checked. Fully charged battery. Antenna, make certain it s tight and unbroken. Wiggle the antenna while receiving, if reception improves, it is the antenna or the antenna jack. Then wiggle the on/off vol switch, same thing, if reception improves, it is broken or needs to be resoldered. Then I check the speaker. Speakers gather metal particles, as they get more and more, the speaker distorts and it sounds like static. Use a powerful magnet, run it over the speaker grill and see if anything comes out. I put plastic wrap on the magnet for easy cleaning. It could still be a bad speaker. Last, I check programming. All of this is done at our shop regularly and I suspect most radio shops follow the same procedures, maybe in a different order. Post if this helps or not.
How to sync and reset stations on radio
gave you a few example
You forgot to mention make ,model
2answers
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 • Cell Phones
Sync two different models
Write the same channel frequency in both radios
What is the FLEET SYNC function in the KPG-119D Kenwood Programing
Fleet Sync is applied to signaling format for data communication. Various functions associated with fleet sync can be configured in Edit Menu.
How do you sync your iphone with the Memorex MA4221 FM Clock Radio for iPod and iPhone
The Memorex is a player only. It does not have the ability to sync, that is, to exchange files with the iPhone. It should be able to play music already saved on the iPhone, however.
1helpful
Radio, CD player, Sync, clock stopped working on my 2008 Ford Explorer
Most likely a fuse. If your fuse box is labeled it will say radio under the fuse. If its not check your owners manual for location of fuse box and radio fuse.
2answers
First time flight
Check to see if the antennas are in tightly and making contact. Check the batteries in the helo that are responsible for radio signal, not the ones for rotor power!
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
