DISHWASHER FILLS WITH WATER FINE, PUMPS WATER OUT FINE BUT CIRCULATES THE WATER VERY WEAK INSIDE. I LOOKED FOR SOME KIND OF WASTE BASKED FOR FILTER BUT I HAVE FOUND NONE
It means the spray arm is not moving correctly. Or there is something blocking it. Make sure you don't load tall glass, large plate or cutting boards. There is no waste basket in a dishwasher, only mesh filters. Unfortuantely, all debris ends up in the motor/pump assy. They do have something called a macerator, which breaks-up large food particles. If this macerator is clogged, you will have to replace it.
SOURCE: DISHWASHER WONT FILL WITH WATER
I don't think that the problem is relates to the leaking water. Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
SOURCE: kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
SOURCE: Dishwasher does not circulate water
I had a similar issue and it was the Motor Circulation Pump. Part #239144 @ Marcone Appliance Parts Center (860) 548-0080
SOURCE: Standing water in the bottom of the dishwasher
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
SOURCE: Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
