Garmin nuvi 780 GPS Logo
L
Linda Olson Posted on Mar 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My garmin nuvi 2555 says battery low and is plugged into the car
My garmin nuvi 2555 says battery is low when it is plugged into the vehicle. Also turns on and off in the middle of the directions
SHARCNET-USA
Level 3:
  • Garmin Master 2,130 Answers
  • Posted on Mar 11, 2014
SHARCNET-USA
Garmin Master
Level 3:
Answers
2130
Questions
Helped
782524
Points
4950
If the unit keeps displaying a pop up window saying that it will be shutting down with a count down timer then the problem is a loose USB port that keeps interrupting power to the unit. The reason why you receive a battery low warning is because the battery doesn't have a chance to charge because of the intermittent USB port. We see this problem all of the time on the Nuvi 11xx, 12xx, 13xx, 14,, and 25xx. We've repaired hundreds. Please see this link on why the problem happens and how we repair this problem so that it won't happen again.
SHARCNET USA Out of Warranty GPS Digital Camera Repair
5 Related Answers
Anonymous
  • Posted on Nov 15, 2008
SOURCE: Garmin Nuvi 200
Guys go to
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=104952
http://pinouts.ru/GPS/garmin_nuvi_power_pinout.shtml
they have the answers
it seems a standard or phone USB cable will not work to charge and use the maps at same time
Good luck
Anonymous
  • Posted on Nov 17, 2008
SOURCE: Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Anonymous
  • 35 Answers
  • Posted on Sep 05, 2009
SOURCE: garmin nuvi 255 won't turn on
Have you tried doing a hard reset,try using the reset button on the bottom of the gps under the serial label.Or try holding the turn off button for about 10 seconds,good luck.
Anonymous
  • Posted on Dec 06, 2009
SOURCE: garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Anonymous
  • 1111 Answers
  • Posted on Mar 13, 2010
SOURCE: my garmin won't turn on. I have tried the plug in
it does have an internal battery, but that normally wont prevent it
from turning on unless the battery is defective.
plug it in to the usb cable on your computer for a while (normally it will start right up) then slide to power switch to the on position for about ten seconds.
if that fails, press and hold the lower right corner of the screen and then slide the power switch to the on position while holding the lower right corner of the screen and follow the directions once it starts
i can give you something else to try before you go and spend money on a battery...a battery should be the last thing to do, even though it will more often then not fix the problem thats tempory..
if it turns out you think you need a battery, i will point you to one with instructions on how to change it.
bill
3answers
My garmin in nuvi 1350 will not charge it keeps saying the battery is low
Nuvi 1350 charges in 4 to 8 hours. If your Nuvi is not accepting a charge, you may have a loose or bad USB cable. Note that the Nuvi can be charged with a phone charger. Charging it with a connection to a computer moves charging time toward 8 hours and more towards infinity if you don't have the driver installed on the computer. Turn the Garmin off. If the driver ins installed in the coputer, plug the Garmin into the computer and then hold down the power button on the Garmin for 30 seconds.
Sep 10, 2017 • Garmin GPS
Garmin nuvi says low battery and it is plugged into the car
The Garmin will tell you 'Low Battery' if its alternative power source is not available for some reason, so the battery is not being charged. Depending how the Garmin has been programmed, the display on some models will become slightly brighter when a power supply, other than its own batteries, is detected. Check for this.
It is likely that the lead you use to plug into the car is not supplying voltage to your Garmin set. If it plugs into a cigarette holder, check that the cigarette lighter works, or plug in another device to see if there is any electricity to the receptacle. Obviously ensure that the ignition switch is on. If the plug-in bit of the power cable has a light on it, check the light is illuminated. if you have a sensitive tongue, you should be able to put the end of the lead that plugs into the Garmin onto your tongue and you will feel a very slight tingle on your tongue if power is getting to the end of the lead. If not, then there is probably a break in the lead inside the plastic insulation or a problem with the supply plug.
If the plug in lead proves serviceable then you should change the batteries in Garmin as one or more may have failed and will not charge. Check for this by leaving the unit on after unplugging the external supply lead. Depending on the Garmin you have, the unit should remain functioning for at least 30 minutes. The internal batteries will degrade rapidly if the unit has not been use for some time and the batteries were not fully charged before you put it to bed.
Need manual for Garmin nuvi2555lm
James,
Your manual is available from Garmin via this link. The nuvi 2555 is functionally identical to the manual in the link. The "lm" part of your model simply stands for "lifetime maps"
If you'd like to check other Garmin nuvi manuals, click here. In the "Market" box, select "On the Road"; in the "Subcategory" box, select "Automotive"; choose the particular nuvi model in the "Product" box.
My nuvi 205 garmin stops working s soon as I
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First Make sure your plug and power cord are working. USE a Garmin charger!!!!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
1helpful
While using my Garmin Nuvi 205W for navigation I plugged it into my car charger and the screen changed to GARMIN with a computer on the bottom, like it was plugged into a USB port. Can I charge my Nuvi...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First make sure you have a Garmin CHARGER.
Notes:
  3. Then Make
    SURE:
  4. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
    After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
    REMEMBER: It takes hours to do a complete a map update.
    Unless you bought the Lifetime maps you may have to pay for current maps.
    Does this help? Let us know. Thanks.
4helpful
2answers
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
1helpful
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Low Battery
Recharge the battery or plug it into your car cigarette lighter and turn the unit on.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
