Hi guys ive got the tyre pressure warning light on my 2000 Corolla 1500, but this light comes on and stays on similtaneously with the ABS warning light. Any ideas on what the cause of this might be, and if so whats the way forward with the problem? Thanks much appreciated.
By operating the tire pressure warning system reset switch, tire pressure warning system ECU can be set to issue a warning at an inflation pressure that corresponds with the type of tires.
Operate the tire pressure warning system reset switch only after the inflation pressures of all 4 tires have been adjusted on the vehicle.
To initialize the system, press and hold the tire pressure warning system reset switch for 3 seconds or longer with the power switch turned IG-ON. When starting the initialization, the tire pressure warning light blinks 3 times at 0.5 Hz.
During the initialization, the tire pressure warning system valve & transmitter measures the inflation
pressure of the tires, and registers the signals that are transmitted into the ECU at a frequency of 1 per
minute. The initialization process is completed when the signals from the tires have been received.
Once the tire pressure warning system reset switch has been pressed, do not turn the Ignition switch OFF for a few minutes.
SOURCE: Recommended tyre pressures (touring) for 1987 Corolla FX
Tyre pressures are partly determined by the tyre manufacturer, partly by the weight you are carrying and partly by the type of driving. When you are touring, up the pressure by about 5 pounds from that recommended. On the average, I would have 37lbs in the front tyres (front wheel drive) and 35lbs in the rear for motorway driving. This will keep the tyres a little cooler.
SOURCE: 1998 RAV4 TYRE PRESSURE??
Thomas Heime is wrong, wrong, wrong! That is the max. pressure that the tyre can handle! the proper tyre pressure is written below the latch on the passenger side door. Open the passenger door, look at the label below the latch and there it is.
SOURCE: What is the tyre size of Toyota Starlet car and what is the tyre?
The tire and that is on it, we'll have the size listed on the side wall. It usually looks like 185/60 R14 or 195/75 R13 or some variation on the numbers but basically in that format. The question is, what size did it come with, what size does it have now, what size do you want to be on there. A seasoned tire store veteran can tell you all of the different variations on size that will fit your car. By a you can select a tire size and type based on ride comfort, winter or wet traction, high speed performance etc. If the tire pressure will also be listed on the sidewall usually in pretty darn tiny letters. Generally 35 PSI that is the Max. 32 usually gives a comfortable ride. air compressors that you can plug in your series cigarette lighter are less than 20 bucks and have a gauge. Please rate this answer.
SOURCE: what is the tyre pressure for toyota echo 2003
STANDARD TYRE PRESSURE IS 28LBS(1.8BAR) CONSTANT HIGH SPEED, IS 32LBS(2.1BAR).I SET ALL OF MINE TO 30 ALL ROUND...AND CHECK EVERY TANK FILL OF GAS.
also all tyre pressures are the same at 2.2bar all around with nitrogen and brake fluid is full.
