SOURCE: Burning smell when ac is turn on
well as for the ford man sorry to here that. I am a holden man myself, but it is most likly that your fan switch is on its way out if you have a test light just pop the switch out and see if you have power to your high setting if not replace your switch. And for mgauthier I would suggest you just reroute your overflow pipe so it overflows onto the ground not onto hot metal parts. But you shouldn't have coolant coming out your overflow all the time. As for burning smell it was probably the switch burning out and failing.
SOURCE: Bad smell coming from heater/ smoke coming out vents
I had the same problem in my 98 Dodge Dakota! Replaced the heater core, problem solved. No more funky coolant smell and erie fog coming through my vents. I bought the heater core at rockauto.com online. Have purchased many items now from them. All factory parts so far at half the price of even AutoZone, even with the shipping. Also, you usually have to wait only a couple of days depending on the part and they have EVERYTHING.
SOURCE: 97 cad sls white smoke near windshield smell like rubber burning
If its in the engine compartment there is an antifreeze leak..If it inside the car like like near to the windshield, you have a bad heater core. Good Luck contact me if you need more help.
SOURCE: White smoke coming from AC and under hoods smells of burning oil
U HAVE A HEATER CORE LEAK, DOES THE SMOKE SMELL SICKY SWEET? AS FAR AS THE CEL GOES HAVE THE SYSTEM TESTED FOR FREE BY ANY KRAGEN AUTO OR AUTOZONE, JUST ASK FOR A OBD 2 TROUBLE CODE TEST, THEN POST THE CODE BACK HERE FOR US TO LOOK AT AND TRY AND DEVELOPE A FIX STRATEGY.
