My tablet does not charge and it vibrates if i try toconnect the charger
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
SOURCE: phone says unable to charge
Try a different battery. If that doesnt work, it may be your charger port. Take an old tooth brush, turn off the phone spray alcahol on the toothbrush, and scrub the port on the phone. If that fails your charger port needs to be replaced. Check with your provider about the warranty. If its not under warranty, check my profile and we can help you for sure.
