Question about Motorola Mobility XOOM Android Tablet
Motorola xoom wont charge
I plug in what i think is the charger and it wont charge what amp/volt is the charger supposed to be
Batoor Khan
    New Friend:
This is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Posted on Mar 10, 2013
  • Carrie Feltham
    Carrie Feltham Dec 01, 2014
    OMG this actually worked! Thank you so much!
My hipstreet pulse 5v charger broke & i have bought several 5v needle chargers that plug into my tablet but wont register or connect to charge it why?
Hi yes the problem using different chargers polarity can be positive & negative. On the male plug or it can be negative & posative ....also they can be AC CURRENT OR DC CURRENT U NEED A MULTIMETER TO TEST THEM ...OR ITCOULD BE a fault with the tablet or the Charging socket .,cheers
Jun 22, 2016 | Tablets & eReaders
Wont take a chargeIve
Either the battery or the charger is shot.
May 26, 2015 | Nextbook Premium 8 Se Android
My nextbook wont hold a charge what do i do
if you have a volt ohm meter check to make sure the charger is working, might be a short in the cable or plug end, its very common
Feb 08, 2015 | Nextbook Tablets & eReaders
What does the lightning bolt inside the battery symbol mean on the screen of the digiland tablet dl700. It wont charge
That symbol means that the tablet battery is plugged in and is supposed to be receiving charging voltage. If the battery is bad, it may not charge but the tablet will still work with the charger plugged in.
Feb 04, 2015 | Tablets & eReaders
My kindle fire does not charge.
If you are truing to charge with a USB post then switch to a wall wart. There is often not enough voltage to charge from USB.
Feb 04, 2015 | Amazon Kindle Fire HD
Galaxt tab3 no start up
I think the first thing you should do if you haven't all ready is check to see if your charger is working or if you know someone else that has the same try their charger. You could also go back to where you got it & they may try one of their other chargers. the only other thing that I can think of is that when the charger was plugged in it was pushed in too hard & the inside plug has broken (hopefully not)
Is it still under warranty ??
Jun 05, 2014 | Samsung Galaxy Tab Tablet PC
My ipad is not charging at all has been completely dead & when i plug it in has a plug picture what can i do?
Are you using the 5 volt 2.1 amp charger. The ipad won't charge with out this charger.
Mar 27, 2014 | Apple iPad 64 GB 3G Tablet PC
My zeepad 7.0 battery is dead
Hi, Zeepad battery is PBS01SHz10 is a japanese battery, similar to nokia BL-5k battery.
Open a zeepad is easy, the problem to find these kind of battery. I am thinking in change the internal connector to adapt the nokia n86 battery, is more easy to find almost here in Venezuela.
Apr 03, 2013 | ZEEPAD VIA8650 Android 2.3 Tablet
My Toshiba Portege M200 just stopped charging and wont even turn on? Is this the battery? Or what? The charger will be plugged in the wall and plugged in the laptop but nothing?
Try removing the battery and see if it will boot without it
Then check the caharger, charging light should be green and steady on the charger itself
If it is flickering, it meand power is not making a circuit, test charger jack with a DC volt multimeter with one probe to the outer side (earth) and one on the inner (positive). If this is ok, check the charging socket is not loose (if it is, will need replacing).
After that, suspect the power strip or charging / powerboard is dead on the motherboard
Mar 22, 2011 | Toshiba Portege M200 Tablet PC
Motorola Mobility XOOM Android Tablet Logo
621 people viewed this question
Top Motorola Mobility Tablets & eReaders Experts
Marvin
Marvin
Are you a Motorola Mobility Tablet and eReader Expert? Answer questions, earn points and help others
