Fuji FinePix Z10fd Digital Camera Logo
Posted on Jun 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Date stamp to appear in the photo
HELP someone, I have the same problem adn this is required for a job :)
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Fuji Master 102,366 Answers
  • Posted on Dec 28, 2012
Fuji Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444338
Points
622693
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
5 Related Answers
informatica
Greg Cann
  • 1114 Answers
  • Posted on Aug 18, 2007
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14901 From page 37 of the manual it looks like you can only select the time stamp in "postcard" mode. Also the date & time need to be set in the camera first. Please update the question & let us know if the information given was useful to you - Good Luck!
Anonymous
  • 203 Answers
  • Posted on Jun 02, 2008
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
Anonymous
  • Posted on Nov 02, 2008
SOURCE: getting date & time to appear on myu photos
I have a sony DSC-T70 and cannot figure out how to add date and time stamp to pictures taken???
Anonymous
  • 18 Answers
  • Posted on Sep 23, 2009
SOURCE: Remove date/time stamp from photos
go to menu at shooting position. scrooll down to date menu and follow the succeding instructions.
old marine
old marine
  • 2426 Answers
  • Posted on Oct 20, 2009
SOURCE: Show/print date stamp on my photos
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
Testimonial: "Perfect! Thank you so much..."
2answers
Date stamp required
Use an external photo editor and export photos with visual date stamp derived from exif info within file. FastStone Image Viewer Powerful and Intuitive Photo Viewer Editor and...
How to remove date and time stamp on photos
Here is tutorial how to remove date stamp: here
I have a Panasonic Lumix DMC-FX520 and the date stamp wont appear on printed photos. The date shows when I take the photo,how do I get the datestamp to show up afterwards
Normally in the menu settings the options are entered so as to stamp the date in. So open menu settings and check on clock and date settings. check for links to date stamping in the menu and activate.
Sep 24, 2010 • Cameras
How do I turn off the automatic date stamp?
What you have to do is click the menu button right of the review pics button. Then click the joystick right then down until its on date stamp option. Click it and then then click the off option. And voila the date stamp is off :-)
I have a Sony DSC-W110 and have set the date adn
you should find a setting on the camera menu that says (time stamp or just stamp). tunr it on and adjust any settings for the stamp appeance
Jan 26, 2010 • Cameras
Date stamp on photos for Canon SD100 IS
I believe you are referring to the PowerShot SX100 IS, as there is no SD100 IS. And yes, it does have the date stamp option while the image size is set to the postcard mode.
Getting date & time to appear on myu photos
Jun 02, 2008 • Cameras
3helpful
2answers
Set the resolution to PostageCard (1600x1200).
Many of these cameras have only ONE RESOLUTION setting which allows you to have a date/ date and time stamp on the file, which will print on the viewed or printed photo.
How to do it:
Turn the camera on M mode.
Use the func. set.
go down the menu to the resolution settings. (on the bottom of menu).
Pick only the postagecard (1600x1200) setting.
I also was like you, and had an awful time with a camera I was fixing. I then looked it up on the Net and found an online user manual for the Canon SD 500, which should be basically the same.
How do you turn off the date stamp from appearing on the photos?
Please spend some time in the menu item referring date stamp, date,record,time if you catch off that item.
For taking 3 pics ,You might have switched on the MULTI in the menu in camera or shooting mode
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
