Fujifilm Finepix AV130 12 megapixels has suddenly started showing a red battery on the screen and then turning itself off before we can take a photo. We have changed the batteries - no luck. We tested the old batteries - they were fully charged. What can we do? Unfortunately we have run out of warranty.
Your camera can work with 2 AA sized batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period.
Always charge sets of batteries together.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
AA manganese (Zinc-Carbon) batteries and NiCd rechargeable batteries cannot be used with this camera.
If you are sure you have good batteries, also check if all contacts are clean and shiny. No oxidation is allowed. To clean contacts never use sharp tools. They can damage the camera forever.
Eventually clean contacts with a cotton swap or a dry cloth.
Also check if no debris is in the battery compartment. Just a little pice of paper can spoil all the (camera) fun.
Just to make sure, try some other batteries, then the ones you are sure of, they are fully charged. Perhaps, next time you are less convinced.
SOURCE: Just bought FUJIFILM FinePix JV100 charged the
Take it back to the vendor, tell them your problem and ask them to demonstrate the camera to your satifaction. If they can't request refund or replacement.
You should have any problems with a new camera.
SOURCE: Hi recently bought a fujiilm
go to ur shop where u've purchased or else go to service centre.......i think the problem must be associated with the power supply....the metal films inside the battery chamber must not be in contact when u put ur batteries...or the battery may be wrongly connected...
SOURCE: Describe your Problem with the
Please get the driver here :
www.fujifilm.com/support/
www.fujifilm.com > Support > Digital Cameras
Kind regards, vote please, Jay
SOURCE: My Fuji Instax mini 7s
14USD e d har dy T-shirts,C00gi
T-shirts,Christian Audigier T-shirts,Gucci T-shirts,Polo T-shirts. 25USD c0ach handbag,gucci handbag,prada
handbag,chanel handbag, 12USD sunglasses,9USD caps. Please visit---- http://www.voguecatch.com ------
SOURCE: My fujifilm finepix s1600 all
hi Does it mean no power at all? So then you have 50 and 50 chance repair for just brown fuse or main pcb replacement. Your local repair shop would charge around $45 to 145 depend on what they really want to charge. Thanks and best regard!
