RH: cavity B (BLK)
Is the voltage within the specified range?
10-15 V
Go to Step 3 yes
Go to Step 5 no
Connect a fused jumper between the appropriate turn signal flasher connector cavities:
LH: cavity C (ORN) to cavity D (YEL)
RH: cavity B (BLK) to cavity F (TAN)
Do the appropriate turn lamps light without flashing?
Go to Step 4 yes
Go to Step 6 no
Replace the turn signal flasher. Refer to Hazard and Turn Signal Flasher Replacement .
Is the repair complete?
Go to Exterior Lights System Check
5
Repair the open in the appropriate circuit:
LH: CKT 57 (ORN) between S200 and the turn signal flasher
RH: CKT 58 (BLK) between S201 and the turn signal flasher
Refer to Wiring Repairs in Wiring Systems.
6
Repair the open in the appropriate circuit between the turn signal flasher and the IP fuse block:
LH: CKT 685 (YEL)
RH: CKT 686 (TAN)
