Computers & Internet Logo
A
Anonymous Posted on Feb 20, 2014
Coolant level checking - MGE Galaxy 3000 UPS System
1helpful
2000 cadillac deville is overheating, replaced thermostat: water pump radiator had head gaskets fixed it's saying check coolant level and it spews coolant from the overflow tank cap when hot thoughts?
Two cooling fans controlled by three relay's . If only one fan is working ,that could be a problem .
Coolant Level Sensor Description
The coolant level sensor monitors the coolant level in the cooling system and indicates if the coolant is low. This sensor is located at the base of the radiator surge tank and is not serviceable.
CHECK COOLANT LEVEL (2)
The IPC receives a discrete input from the engine coolant level switch. The engine coolant level switch is normally closed. When the engine coolant is low, the engine coolant level switch opens. When the IPC receives an open signal from the engine coolant level switch, the IPC displays the message on the DIC.
Relay Driven Dual Cooling Fan Diagnostics There are using a pontiac , by your cadillac is the same .
1helpful
My dashboard LOW COOLANT light came on, I had the radiatior flushed, and the light is still blinks
You should first check your coolant overflow tank to make sure there is the proper amount of coolant in it. You MUST check the coolant level when the engine is cold to get a proper reading of the level of coolant. When you open a car's coolant system to flush it is common to get air bubbles in the engine. As the engine warms up, the coolant expands and the excess goes into the overflow tank. When the engine cools, the coolant contracts and it draws coolant from the overflow tank. So, after a flush, you must check the level of the coolant the next couple of times you drive your car because it will take several expanding and contracting cycles for all of the air bubbles to be forced out of the engine. If the level is the same after checking it a couple of times, then you should open the radiator cap check the level there. It should be at the very top of the radiator. (MAKE SURE THE ENGINE IS COLD OR YOU WILL GET BURNED!!!).
If insuring the engine has the proper level of coolant doesn't correct the low coolant light, the next step would be to replace the sensor. In most engines it is just a screw-in plug with a wire on it that transmits to the low coolant gauge in the dash. Most automotive part stores should be able to look up where it is located. It is like changing a spark plug, but you may loose a little coolant out of the engine when you remove the old one, so check the coolant level after changing it.
Good Luck!
2answers
Cooling system
Raise the car front end as high as possible with a floor jack, fill the coolant tank to the top, run the engine until it reaches just short of overheating, shut it down and run water over the radiator, this will burp the air out. Repeat as needed. Don't let the coolant recovery tank run dry during procedure.
I have a yellow light on that looks like a long tool
if you see a wrench light come you have mechanical fault. check engine oil level,check coolant level make sure plenty coolant in radiator and coolant over flow reservoir has coolant level to full cold mark, check power steering fluid level.if al is good have vechicle code scan.
2helpful
How do i remove engine coolant cap on 2001 cadillac dhs
WAIT UNTIL YOUR ENGINE IS COLD,YOUR RADIATOR PRESSURE CAP IS LOCATED ON THE COOLANT OVER FLOW RESERVOIR, THATS WHERE YOU ADD COOLANT WHEN COOLANT LOW,YOU POUR COOLANT IN THE OVER FLOW RESERVOIR UNTIL COOLANT LEVEL REMAIN AT FULL COLD MARK DONT OVER FILL OVER FLOW RESERVOIR, WHEN COOLANT LEVEL STOP DROPPING WHEN ADDING COOLANT AND COOLANT LEVEL STAY AT COLD MARK ON THE RESERVOIR YOU RADIATOR HAS THE CORRECT COOLANT LEVEL IF COOLANT LEVEL KEEP DROPPING CHECK FOR COOLANT LEAKS AROUND RADIATOR AND THE TOP AND BOTTOM RADIATOR HOSES, LOOK FOR COOLANT LEAK AT WATER PUMP GASKET OR SEAL OR LEAK AT WATER PUMP WEEP HOLE IF YES REPLACE WATER PUMP.
4helpful
A light come on with a box with arrow pointing down looks like waves what does it mean
This indicates a low level of coolant in the coolant bottle/resevoir..... this symbol represents the radiator or coolant system liquid level.
Warning comes on to warn of coolant level too low.
When the engine is cold...remove the cap and check level. Add 50/50 antifreeze/water to level indicated on the side of the coolant bottle or tank.
Reservoir Bottles/tanks are usually transparent and you can see the coolant level through the plastic.
When coolant topped off to correct level, lamp will go out automaticly...no need for scanner or shop to turn it off. It will come on as a 'self check' when you turn on the ignition and if level is okay will go out when engine starts.
1helpful
Vw jetta iv, temperature alarm sounds and flash with no aparent reason. temperature dial indiator is ok.
I WOULD CHECK BOTH RADIATOR HOSES TO MAKE SURE THEY ARE HOT. THERMOSTAT COULD BE STICKING SLIGHTLY CLOSED.CHECK COOLANT LEVEL MAKE SURE COOLANT NOT LOW.IF COOLING NOT BOILING OUT OF THE EXPANSION TANK. I WOULD HAVE CAR HOOKED UP TO A DIAGNOTIC SCANNER AND CHECK COOLANT TEMPERATURE SEE IF TEMP. OVER 230 DEGREES IF SO RADIATOR COOLING FANS NOT WORKING.COOLANT THERMO SWITCH BAD BOTH FANS SHOULD BE RUNNING AT LOW SPEED.IF ALL LOOKS GOOD YOU COULD HAVE FAULTY LOW COOLANT SENSOR IN EXPANSION TANK.MAKE SURE COOLANT IS IN THE EXPANSION TANK BECAUSE COOLANT LEVEL COULD BE LOW.ADD COOLANT IN THE EXPANSION TANK UNTIL YOU AT MAX LEVEL LINE ON THE EXPANSION TANK.DONT OVER FILL THE EXPANSION KEEP ADDING COOLANT UNTIL COOLANT LEVEL STAYS AT THE MAX LEVEL LINE ON THE EXPANSION TANK.
6helpful
4answers
Car overheating no heat coming from vents just cold air
NO heat because there is no coolant flowing throught the heaster core. Car is overheat since there is no coolant circulating in engine water jacket.
Check the coolant, if it is low, then check the oil level. If oil level is high then the head gasket is blown so coolant gets into the engine therefore there is not enough coolant to cool the engine.
If the oil level is OK and coolant level is OK then Need to check 3 following things:
-Bad thermostat is not open causing coolant stagnant then engine overhet.
-Bad water pump is not pumping coolant so there is no coolant circulating to disipate the heat.
-Bad radiator blocks the coolant flow from top to bottom radiator.
Good luck.
Top MGE Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
