Cars & Trucks Logo
Posted on Jun 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No idle on 96 Suburban
Idled fine yesterday. This morning I started it, backed it up a short distance in my driveway and put it in park where it immediately died. Now it will not idle at all- goes straight to dead if I let off the pedal. It drives fine but will not hold any rpm's in neutral.
  • Anonymous May 11, 2010
    Clean the cross wires inside the mass air flow sensor with a q tip and carb cleaner and see if condition improves. I't s located between the large duct sections going from the air cleaner to the throttle body.
Anonymous
Level 3:
President:
  • Master 1,392 Answers
  • Posted on Jun 09, 2009
Anonymous
Master
Level 3:
President:
Answers
1392
Questions
0
Helped
657573
Points
4859
Check IAC motor, or vacuum leak somewhere.
1992 Buick Park Ave. won't start after pressing brake pedal.
sometimes the other switch is to cut out the cruise control when the brake is applied. I would more suspect something in the fuel injection controls such as a mass air flow sensor or throttle "switch." your car is probably too old to have an auxiliary air bypass valve but if it has one look at it as well. good luck
Car wont start after putting regular gas in it
Do you have normal fuel pressure ?
Will it try to start using starting fluid sprayed into the intake ?
2helpful
2000 gmc safari parked in the rain won't start
Did you take the distributor cap off and see if it has moisture inside ?
Same problem
throttle is probably going out you can try to clean it but they are usually bad when the epc light is on
5helpful
2answers
Key is on....battery is good....engine won't turn over
Black box (plastic) usually pretty handy to battery, you should see red (usually) cable from battery running to it. Another thing that came to mind, you don't have anti-theft system on that do you? Sometimes they will cause problems after a dead battery. Try using your key & valet key to unlock the doors, manually especially drivers.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
