My son accidently hit the set menu button on the remote andnow we can't get out of the set up mode. I have read the manual and followed the steps and can't seem to get out of set up mode.
De power the main Amp, then remove the batteries from the remote, then power up the main set again and then put the batteries back in the remote...Its like a re-boot of a computer it just might work for you....Signed of as YUBEUT
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
Here is the code: I did this with the remote Press stop twice(which is also the BAND button) Press 1,2,6,4 Press down 1 time(button below the Play/Enter) Press Play/Enter 1 time (You should now see the menu) Brake override should say No I was told to change macrovision to No Hit sys setup twice to save and exit Hope it works like mine did!
From the front screen and keyboard:
(i.e. with the phone closed)
While entering a message, hit the main "OK" button for "Options".
Item #2 in this menu is "Entry Mode."
T9 is on this list.
Operating from the internal LCD screen and QWERTY keyboard:
Hit OK to get to main menu
Select "Messages"
Once in that menu, the left option key beneath the main LCD screen is "Settings" - hit that
On that menu, item #2 is "Entry Mode" where you can select T9
I have read of difficulties getting the enV3 T9 mode to add new "user" words that you might want to program into the T9 dictionary, so don't be surprised if you have trouble with that.
Do this, and don't worry about the parking break wire.
The parking brake bypass procedure is as follows:
1: Go into AM/FM mode 2: Hit "setup" on the remote control 3: Enter 543210 on the remote, listening for the beep for each number entered 4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen. 5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen. 6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
I scratched my head over this for an hour. The manual says you can access the OSD from the unit, but I see no way to do this. From the remote, you have to select the "AMP" setting at the top of the input list. Then hit the OSD button. Assuming your monitor is set up correctly, this will bring up the On Screen Display. Then hit the "Menu" button also on the remote, and you can make your adjustments. Good luck!
