Unable to install applications from pc to my phone
When ever i download any apllication and try to transfer it to my phone, it get transfered but when i am trying to open it,it shows unsupported file system .............
There are three ways that you can install your Nokia themes on your
phone. One is through over the air downloads, in which case, you just go
directly to the site with your chosen theme, click on the link, and
follow the instructions on your phone.
If you're downloading the
themes on your PC, there are two ways you can install it on your mobile
phone. One is through the Nokia PC suite, and the other is through
Bluetooth or data cable transfer. follow these instructions
Using Nokia PC Suite: 1. Connect your phone to your PC and turn on the Nokia PC Suite or wait for the application to start. 2. Click on the "Install Applications" 3. When a window appears, browse to where you have saved the downloaded themes using the left part of the window. 4. Select your chosen theme and then press the arrow in the middle of the window 5. Follow the instructions on your phone screen and you're done.
Bluetooth or Data transfer (only for N-series and newer phone versions) 1. Data transfer.
Connect your phone via USB cable and select "data transfer" on the mode
menu. When you connect your phone and it shows up as a removable disk,
transfer the theme on your phone's storage card. You can install the
theme by using the file manager and selecting the theme to install. 2. Bluetooth.
If your friend has a theme on their phone, you can have them transfer
it on your phone via Bluetooth transfer. The theme will appear on your
messages and to install it, simply click on the transferred file on your
messages and follow the prompts.
If your computer has got viruses then you can you can download it form internet and transfer it to your mobile phone or a pen drive. Transferring it to your pen drive is a better option because if you transfer it to your phone and when you connect your phone then it may get viruses this will create more problem .
If you are having a pen drive then copy the anti virus to it and then connect the pen drive to your PC and install it.
If you are not having a pen drive then a memory card will also do , you can connect the memory card to your PC with the help of Card Reader.
But if you are not having any other alternative then you may go with phone.
Hope the above information will be helpful you. Thanks.
Sony Ericsson F305 supprots only Java softwares. Download the java apllications which you need from www.getjar.com after selecting your particular mobile model. The extension of the application should be ".Jar" Then transfer this jar file to your mobile and try installing it. The installation files transfered from other mobiles using bluetooth may not be compactible with your mobile. If your problem still exist, then activate the GRPS, go to wap.getjar.com and try downloading the application directly to your mobile. This should work fine. I hope this is helpful to you.
go 2 http://www.mobilerated.com/samsung-gt-e1410-games.html Download .jad as well as .jar files from the website
transfer it 2 mobile via bluetooth r u can buy a memory card reader,which costs less than 100 rs.transfer it 2 memory card.ten move it 2 phone memory and install that. u cannot install it directly.there r some steps to follow. To help others i've written it clearly here how 2 install visit http://techbuzz9.blogspot.com/2009/03/samsunge1410.html
All phones are different, but if you already have the usb cable, simple plug it in! If windows comes up with a "Searching for driver" window, then great! Let it finish and try accessing the USB device via the hard disk icon it creates in "my computer". Otherwise you may need to use the software that came with the USB cable.
