Cars & Trucks Logo
Posted on Aug 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code PO0171 & PO0174
I Have a 1999 Chevy suburban which I just put a reman engine in.
the truck starts real good and idels smooth but I keek getting the lean engine codes, and it runs bad when under a load.
I have replaced all the sensors but still the same codes.
Also have put in new fuel Injectors, spark plugs, wires.
still runs the same. can any one help me with this?
  • Anonymous May 11, 2010
    What engine?
  • Marvin
    Marvin May 11, 2010
    these are invalid codes
Jeffrey Turcotte
Level 3:
  • Ford Master 8,991 Answers
  • Posted on Aug 31, 2017
Jeffrey Turcotte
Ford Master
Level 3:
Answers
8991
Questions
7
Helped
4373244
Points
33683
You have a vacuum leak. Did you use new intake manifold gaskets and torque the bolts according to the spec? Did you get all of the vacuum lines back on in the right places?
5 Related Answers
Anonymous
  • 1486 Answers
  • Posted on Jul 18, 2009
SOURCE: ford 4.6 code po174 bank 2 too lean
O2 sensor faulty.
Anonymous
  • 15 Answers
  • Posted on Jul 20, 2009
SOURCE: Hesitation and stumbling.
Before you do that, check which thermostat it has in it, if it has one that is letting it get too warm or not completely up to temp when the computer think it should be, it would cause this. My 2000 crown vic did the same thing and thats what it was.
Kerry Davis
  • Posted on Aug 14, 2009
SOURCE: 2001 Ford F150 V6, Truck started spitting and
i know that the 5.4l are known too misfire if you wash them because the water runs down between the coil and the heads. pull all your coilpacks and check for rust on the spring in the boot and use compressed air to blow any exessive mosture out of the coil to plug area.
Anonymous
  • 534 Answers
  • Posted on Aug 18, 2009
SOURCE: Have a 2003 Taurus, 3.0 engine that has a misfire
Sound like an air / vacuum leak to me.
Re-check for an air leak on #2 cylinder inlet manifold.
Use a propane torch (unlit, of course) to flood propane gas around inlet manifold/head flange & gasket area.
If there is any change in idle speed during this test you have a vacuum leak.
Anonymous
  • 144 Answers
  • Posted on Sep 17, 2009
SOURCE: Ford 150 runs rough when cold
Hi! Either the elbow at back of intake manifold is leaking or your intake gaskets are leaking. A very common occurance on both items and either one will set a lean code and illuminate the check engine light. Hope this info helps!
Hello. I have a 88 5.7 that was put into a
Your base timing may be off. But a 1969 suburban did not have a computer??
Chevy suburban
Hi Jeff
Fault code P0456 means evaporator emission control small leak detected.
you need to check the tank filling cap, evaporator valve, hoses and connection for leak.
Good Luck
1996 GMC jimmy rough idel and dieing when driving.
i have seen many strange things happen with the distrib cabs on these
2answers
99 Chevy suburban code #1 c0310, #2 c0323, #3 91...it just had an engine replacement and does start idles smooth at first but as it warms up it gets rougher w a little shake
Those codes are for your 4X4
C0310 is for Motor A/B Circuit Open
C0323 is for T-Case Lock Circuit Low
Check the wiring harness for loosness or possible broken wires. or dirt in the connectors. These codes should have no affect on how the engine runs.
When engine light comes on the transmission shifts differently & when its not on it shifts real good
This is real common on gm trucks. The valve body will need to be changed. Reman valve bodies are all over. Cost should be about 300-500
1helpful
Idels high shifts hard and that is like every other time started put in new ecm and still have the issue
Your describing a vacume leak or a mis adjusted throttle body. Does it ever idel down? What engine is in it Desiel? If it's gas the AIS motor might be sticking or is bad. Does it run and is the check engine light on? are all the fluilds correct level? coolant level low can make the coolant senser lie about the temperture of the motor to the ecm and it'll command a high idel. Once the idel motor goes as high as it can it might be shicking and you can remove it and wash it off with carb spray and while it's out with the wire connected turn the key on and off with it in your hand and spray it with cleaner till it moves smoothly. With it retracted install it and try again, any vacume leak will make it idel fast. The trans mission will shift hard if the vacume line to it is off and it's on the back of the intake manifold and it goes to a modulater on the side of the trans. it can be off there too.
1999 Chevy Suburban 5.7 V8 Starts fine will run smooth, but will not take fast throttle. If stomp the gas it will die and pop. It will reach interstate speeds and run smoothly if only minimum throttle...
ok here we go, hook up a feul pressure guage that can be read from inside the car, and check fuel pressure while driving, if the pressure stays fairly constant then the best bet is to hook up a real time scanner with snapshot capabilities ( like snap on or bdm pro) and take it for a drive again, ti could be a sensor reading out of range but not enough to set a code
2helpful
2answers
Is it worth it to replace a transfer case on a 1999 Chevy Suburban? And if I do where is a good place in the Port Huron, (Northern Detroit) Michigan to get parts?
I cant make the call. Think of it this way, do you like the truck, and what shape is it in. I see your in michigan, salt can be a killer on the truck. But if its in good shape and you like it go for it. Shops or wrecking yards in your area I just don't know.
3helpful
2answers
1995 suburban idles, but dies when put in drive.
check for vacuum leaks at throttle body gasket. pvc valve stuck open.if all is good .change fuel filter .if still stall out check fuel pump pressure.if all is good .replace plugs and wires if they have not been changed.
1helpful
2002 NEON IDELS ROUGH AND IDELS HIGH RPM.
sounds like the intake hose from throttle body is not on intake manifold properly..as for the p0700 trouble code,you need trans controller scanned for fault codes..let me know what codes are in trans controller
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
