If the LCD panel gets damaged, crystalline liquid leakage may occur, or scattered broken glass may result. Do not touch broken glass or crystalline liquid (which is toxic), with bare hands as cuts or poisoning/skin irritation may occur. Also, do not let glass fragments or leaked crystalline liquid get into your eyes or mouth. Should either contact your eyes or mouth, rinse the contacted area thoroughly with water and consult your doctor.
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
Propane exist in a liquid state when it is under pressure in a propane cylinder. When the valve on the propane cylinder the pressure on the liquid is reduced and the propane reverts back to gas state.
Also, regarding the tank you need....
the owners manual probably states what size you will need but, with most heater like the one you have it will require a 100 lb tank (approximately 25 gallons). You will also need an inline regulator set to 11" to 14" of water column between the tank and the heater.
Correct me if I'm wrong but the 250SX is a 2 Stroke engine with a Gas (1.98 Gals Unleaded Premium 91 octane Recommended) to Oil Mixture (using Motorex Cross Power 2T at a 40:1 - 60:1 depends on oil quality) and when KTM says to Change the transmission oil the amount called for is 0.7 liters engine oil using Motorex Top Speed 4T 15W50.
These Quanities are from an 04 250SX could not find a 2000. So consult with your local KTM Dealer's Service Department and pickup a Owners Manual at the same time it would be in your best interest.
Liter breakdown
0.7 liters = 0.739681 quart (US liquid) OR 0 quart (US liquid) and 1.47936 pt (US Liquid) / 0.7 liters = 1.47936 pt (US Liquid) OR 1 pt (US Liquid) and 0.958726 cups (US)
Where can i get a remote to purchase,and how much will it cost.
