The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Hello Friend, this is Z. Thank you for allowing me to assist you!
If you are getting an error code F1, it usually means that your Frigidaire range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
My range was doing the same thing. I finally called the Consumer Protection Agency and reported it. It launched a national recall. With their help, Frigidaire replaced my range. On Easter 2014, the new one did the same thing. Burner turned on by itself, to 8.5 with knob in the off position. We had to unplug it. Frigidaire once again did not care. I contacted the CPSA again - they are investigating. I will NEVER have another Frigidaire Range. Check your model number against the recall information. Don't trust it! It is a fire hazard.
If it is a thermal cutoff then a 0 ohm reading means it is bad. Many other devices may not be able to get an ohms reading even if they are good. For instance anything that has inductive reactance or capacitive reactance. So you have to know what type of device you are testing so that you know what to expect and what methods are needed to test it.
