When sellect defrost vent a/c floor for air sellection the air blows from all of the vents
SOURCE: 2005 Merc. Grand Marquis a/c full blower does not
it not a motor its a module and you have look behind the radio in the dash and find it the dirrection section is not working for the area you dont get air
Testimonial: "The help was moderately helpful. However, we wanted more technical info. Like do we have to take the radio out? Can we access module from outside?"
SOURCE: 2004 mecury grand marquis heater or ac will not
check the doors in the heater ductin and make sure all the door motors r workin properly
SOURCE: air flow changes by itself
the vaccumm motors that actuate the mode doors are vaccumm driven.
if at idle all is ok then under accelleration mode doors change then there is a vaccumm leak in the system. look for a steel can (coffee Can) under the hood. trace the vacumm lines from there.
SOURCE: no air blows from vent
Check for a cracked or broken vacuum hose under the hood, close to the cow panel....
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
