SOURCE: how do i know if my amp is blown
Hey Yoo, Go to Radio shack and get you an adapter that will take an earphone jack and convert it to RCA male. You use this to simulate the signal coming from the reciever. Hook up to a Cd player or Walkman, anything with an earphone output jack. Test that the device actually puts out music or anything worth listening to. Connect the device to the input of your amp, with the car running, and the reciever turned on.. This will tell yo if the signal is getting from the reciever to the amp. You may not be getting signal from the head unit. If you still get no sound to the woofers, dsisconnect the woofers and try a different speaker. If that speaker dont work, Change setting and switches., and if you still get no sound, then your amp is toast.
SOURCE: fuzzy sound from right front speaker output
The main issue is to determine where the distortion is coming from. Does it start in the front and and get amplified or does it appear in the output section only? This will require a fixed signal and an oscilloscope to trace. Check for leaky coupling caps or leaky transistors in at the diff-amp section.
Dan
SOURCE: getting speakers to all work
You are probily set to phantom or stereo, set to dolby digital or movie. Most likley a button labled sarround.
SOURCE: Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
