When I turn my ipod on,it goes to the apple icon, and loads, then it freezes, and after awhile it goes to a white screen and turns off. I tried to plug it onto iTunes to try to fix my problem from there, but I don't think its detecting my ipod either. so I cant evenccess it from my laptop
SOURCE: my mini ipod freezing, showing charger sign i could not turn it to menu
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
SOURCE: Ipod nano not detected by windows and itunes
There are a couple of things you can try:
Make sure you have updated to the latest version of iTunes.
To reset your iPod:
How to restore your iPod:
For Windows:
THIS WILL ERASE ALL SONGS, VIDEOS, PODCASTS FROM THE IPOD AND SET IT BACK TO THE FACTORY SETTINGS
These steps usually will fix the issue...I hope that helps!
SOURCE: 80gb ipod classic won't turn on!
hey please help me out ... I have the same problem now ....pls
SOURCE: my ipod is frozen. I was trying to restar it but
have you already attempted to reset the iPod by pressing and holding both the menu and center buttons for at least ten seconds; or until an apple icon appears on the screen?
If not I would recommend that as your first trouble shooting step in attempting to resolve this issue.
SOURCE: White screen on ipod, 2 beeps on restart
I just had this problem as well, i tried everything, so i let it sit here for like a month, while deciding what to do with it. I just found a response today that said if you don't care about losing it try dropping it on the floor a few times, I'm not kidding you that it worked lol. After i dropped it twice I restarted it and the apple logo showed up and works fine now, anyways hope this helps, although i don't know that I'd recommend it for everything it did work for me.
