The unit stops syncing with the Wii and does not respond for several seconds,,,up to 20 or 30...then does the same thing again...
This is after unit is fully charged and only after about an hour of game play.
I took it back and got another one, with the excact same results!
Replacing with my regular batteries fixes the problem, but not the out of pocket expense!
I wish I could play for an hour! My controllers won't even register movement, so I can't even play with them. I put in regular batteries and it's fine. Wish I could help you. Seems this charging dock is a great idea with a few major bugs still in it.
You will first need to make sure your Wii remotes have batteries. Then, turn on your Wii and go to the Wii menu.
Open the little white door on the front of the Wii game console (this may require using your fingernail). You will notice a little rectangular red button.
Open the battery compartment of your Wii controller, which may require removing the rubber jacket. You will notice a little round red button there.
Press and hold the red button on the Wii game system and the red button on the Wii remote at the same time for at least 2 seconds. I usually hold down the remote button, then press the game console button for 2 seconds because it is easier for me. You will notice the 4 little blue lights on the front of the controller blink many times. The lights will eventually stop blinking and one of the four lights will remain on. The light that remains on tells which number Wii remote you have. The one on the left is number 1. The second from the left is number 2, etc.
*** If you bring your remotes to a friend's house to play, don't forget to sync your remotes back to your Wii console when you get home.
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
I would try to re-sync the controller to the console. 1. Power on Wii 2. remove battery cover from wii remote; press sync button on remote, will cause LED's on remote to blink. 3. Press the sync button on the console (it is located in the memory card holder on the front of the console) 4. The remote is connected once the LED stops blinking. The lit LED indicated what player # the connected controller refers to.
If you are still having trouble then delete the configuration info first and then re-sync the controller to the Wii. Do this by holding the SYNC button on the console for 15 seconds after turning the unit on (once you see the health and safety screen). After you do this you will need to re-sync the controller individually.
It also warns of bright light sources like sunlight near the sensor bar, highly reflective surfaces (mirros, etc.) behind the sensor bar, sources of infrared radiation (portable heaters or fireplaces) or radio interference from cordless phones, cell phones, etc. as possible causes of interference. See pages 22, 32, 34 of your Wii owner's manual for full information, or call 1-800-255-3700 if you are still having difficulty.
1. Remove the second Wii Remote's battery cover and insert two AA batteries into the device. 2. Open the SD Card Slot cover on the front of the Wii console. Push and release the console's "SYNC" button. 3. Push and release the "SYNC" button below the Wii Remote's batteries. 4. Wait for the Wii Remote LED to stop blinking. 5. Replace the Wii Remote battery cover. 6. Snap
the Wii Remote into the back of the second Logitech Wireless Guitar
Controller for Wii. Your second guitar will then use your Wii Remote's
power and synchronization to the console and respond to Guitar Hero.
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
You need to put in the Wii fit game and bypass all the screens until it is looking for play options.Take the battery cover off of the Wii board and open the large cover on the front of the Wii console.Press the sync button inside the battery compartment on the board,then press the red sync button at the top of the open console.If the blue light stays on constant,they are synched.If not,try again.Good luck and Game On!
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds.
After a few seconds have elapsed, plug the cord back into the wall
outlet.
Turn
the power of the Wii console ON. When you see the Health and Safety
screen, open the small flap on the front of the Wii console to find a
red button labeled "SYNC." Press and hold the SYNC Button down for 15
seconds. This will clear all the syncs on the Wii, allowing you to get
a clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at
least 15 seconds, you can now "re-sync" your Wii Remotes:
With
the first Wii Remote you wish to sync, remove the battery cover on the
back of the Wii Remote to find a small red button just below the
batteries.
Press and release the small red button just below the batteries on
the Wii Remote; the blue lights on the front of the Wii Remote
will blink.
Quickly press and release the red SYNC button on the inside of the
white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED
that is illuminated indicates the player number (1 through
4).
This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote
added to the system.
Hi. I got the same thing playing GH but without the nunchuck. Use the hand controller to re-sync. Press the sync button on the console FIRST and then the sync button on the hand controller SECOND.
I sat for hours trying to work it out - and it cleared the problem within seconds. Hope it works for you too.
1, Turn off and unplug your wii console for a few minutes
2,Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
* Then remove the battery cover from the wii remote, inside you will see another red button.
* Press and release the red button, the blue lights on the remote will start blinking.
* Quickly press and release the red sync button on the wii console.
* The remote will stop blinking and it should now be synced.
then try syncing your wii fit bored
My husband fixed my wii balance board, it's the sync button. The button on the switch is too long and if there's any lateral stress it resets. The switch toggles, not just up and down when you push the sync button. Hubby took the board apart, took out the sync switch, trimmed the button by 1/2 the length, it's now recessed and when there's lateral stress, no resetting or re-sync happens. It works perfectly and never loses connection no matter what i'm playing! You can still re-sync the board, but need to use a paperclip or pen to push on the botton
