The vehicle is rough at idol and no power especially when its cold. Only at high rev got some power until its warms up but the rough idol is still remain. Many times was stall in traffic when had to stop. Any ideas what could be wrong?
It can be issue
with IAC( idle air control valve) causing the problem.
There
are many other possibilities causing these idle issues. Engine idles rough.
There
are few help links with solutions to troubleshoot such idle issues.
I
suggest you refer the link below and follow
its troubleshooting details:------
Click
the link below:-----
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to
3500 rpms
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High
Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These
details will help.
Thanks.
