I have an emachine e627 and want to increase the memory. Is that possible?
SOURCE: I Have an Emachine E627 Laptop and I'd like to use my webcam
I have an emachines e627 and it has a webcam, because there are different models of the emachines e627. Most likely you have an emachines e627-5583, that model has a webcam. If you are trying to use your webcam there is a program that is built in called just go to "C:\Windows\Video Web Camera.exe". I hope this works for you
SOURCE: emachine laptop E627
I think you are telling about the adapter if you are trying to insert a micro sd card then insert the card in the adapter and then try to insert it in the slot if you are using a big sd card then directly insert it in the slot.
SOURCE: I have a emachine E627 laptop how do I use webcam
Just go to TestMyCam.com if there is no camera detected...you don't have one.
SOURCE: emachine E627-5583 does it have a built in microphone?
The best way to check is to click on Start menu> right click on Computer/My Cpmputer> Properties> Device Manger and check if the webcam is listed in it. If it is listed then the computer has Web cam.
SOURCE: need to know if a
In short yes it can, however, depending on your location prices can very dramatically. I would take the laptop to alocal repair professional and obtain a quote, but it can be sometimes cheaper to replac the whole laptop.
Good luck
Rytech Computer Services Limited
