Intermec EasyCoder  PC4 Label Printer Logo
A
Anonymous Posted on Jan 25, 2014
Intermec PC4 wil not print - Intermec EasyCoder PC4 Label Printer
5 Related Answers
Anonymous
  • 88 Answers
  • Posted on Jun 21, 2008
SOURCE: Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
Anonymous
  • 6 Answers
  • Posted on Aug 15, 2008
SOURCE: Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Anonymous
  • 1049 Answers
  • Posted on Oct 02, 2009
SOURCE: Intermec PC4 is skipping over blank labels when it
Make sure that the label is not larger than the printable area, carriage returns and spaces count as part of the label too. Also make sure that in the printer properties you didn't set the page width wider or higher than the actual label. Especially using MS Word, you may have to adjust the label slightly smaller to compensate for margin, header, and footer settings. Also be careful of mail merges which merge data larger than the viewable area on the label.
Anonymous
  • Posted on May 12, 2010
SOURCE: Intermec EasyCoder PC4 Label Printer
JUST PUT IN TO PORT COM3 AND GO.
ozztech
Paulo Rangel
  • 285 Answers
  • Posted on Nov 12, 2010
SOURCE: Where can I buy a couple of new Intermec EasyCoder
were you locate?
Australia - Peacocks.com.au
How to adjust intermec to print thicker labels
Only user Intermec Labels or they will probably not work.
Label height is not managed correctly on the intermec easycoder PC4 that I got second hand... How to deal with this issue???
Go to printer properties and put in the custom label size. You will need to do this for each user of the computer.
I need intallation guide of intermec easycoder pc4 & driver download link hlp me thanks
http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
1helpful
Check now.
PC4 doesnt appear to recognize ANY IPL coding
1. Add Generic Printer to printer list.
2. Select Generic printer as Default printer
3. open the document and print.
4helpful
3answers
1helpful
Top Intermec Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
