We were travelling back from coffs hbr I had to wait for a valid signal for over 3 hours what could be the problem. les
SOURCE: signal
First thing ensure that the TomTom is fullly charged using the home charger.
Press the small reset button on the base (700) or do a factory reset.
The other thing to try is tap the GPS signal bars to go to the configure and check in the top right hand corner there is a circle with yellow and black esgments if this is moving then your TomTom is looking for a signal. Move around and you should find that the bars at the bottom will start to move and the small screen on the right will start to indicate circles. When the bars start to move you are getting GPS signals when the bars change to blue there you have a coordination for your position. Some areas are worse than others so move out of your house if after doing above does not get a signal
SOURCE: tom tom comes on but,no gps signal lost for hours.
hi you need to reset the unit at the back near the connection there is a small button that needs to be held down when holding the power button on for a few seconds. once you have done this turn it on and it will work fine
SOURCE: waiting for valid gps signal
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
SOURCE: tom tom one wont detect gps signal
my tomtom wont get a signal and is saying are you in a building?
SOURCE: My tomtom one 130 will not pick up a valid GPS
Install Tomtom Home on your pc and connect your gps on it.Do not update the firmware yet, but ony the "gpsfix" program. If it does not work, try a reset by holding the power button for 15 seconds.Let´´s get in touch
